Need sub for good S.Q.
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 694
  • 2
U
Unregistered
Guest
What is the best sub for S.Q. I don't listen to much rap or R&B so a lot of boom isn't wanted. I'm looking for tight strong bass. Also, how much power should be used to run it. (As much as the RMS or under?)
Depends on how much $$ you have to spend. A few subs come to mind that are pretty affordable: Alpine, Infinity, JL Audio.
RMS is the only number you need to worry about. It really doesn't matter whether your amp is capable of pushing more or less than the sub is rated for. What matters is how the gains are set, and how you use your volume control. A good class AB amp will help out your SQ a little. If you don't want a lot of boom, I would suggest getting 10's, you could maybe even get away with one.
I'd be willing to pay for a quality HU, if it meant that I can truly get the sound quality I need. I've seen some aftermarket ones that look...
10
985
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Guest
Phatillusion
    May 24, 2024
