Need some info.
SVTLightning01
I recently bought a 2004 325Ci with the HK premium sound system (yea right).
The car has 10 speakers in it. In the front doors, it has a tweeter, 2.5speaker and a 6.25 speaker. Im replacing the doors with a set of diamond d651 components off a pg amp.
The rear deck has 2 6x9 speakers (as they call the subwoofers). My question is, should i just put a good set of 6x9s to replace them, or should i do a another set of comps? I have 2 channels left on the amp, 50watts a channel. Not sure what actual rms is since i havent recieved the amp in the mail yet.
Ive looked into the diamond d391 coaxials, kicker ds, and have owned pioneer before. Im sure the comps im putting in will give me the highs im looking for since its a small coupe. What would be my best option for more mid-low bass without putting a sub in. I will put a sub in later, just want something to get me by for now.
Thanks.
ive looked at those, but my amp is 50 x4 @4ohm. 8 ohm wouldnt do me any good.
Does your substage need to be in stereo?
If not you could wire them in parallel with each other and then bridge those two open amp channels to a mono bridged channel and drive them that way...
Certainly you don't have to go with the Tang Bands but it's a really economical solution that uses the space currently available without having to do any cutting. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
In my car, i through out all 10 (they count the tweeters and mids as seperate speakers even though they're all part of the same crappy component set) stock speakers and put some Type X's in the front and a pair of IDmax's in the trunk. I know there's not a lot of info on the type X's out there, but those things have TONS of midbass and they blend in with the subs quite nicely.
IMO, forget about the rears and buy the nicest component set you can afford for the front stage and then save up for a nicely designed, ported box and a high quality 12" sub.
Also...check out http://forum.e46fanatics.com/forumdisplay.php?f=22
im on e46fanatics, just figured ca.com would be more of a help. i will probably do that, i have a d610d4 and a m612mkII at home. Ill just do the comps for now. Since i have 2 extra channels, should i just bridge both doors? Should put me at about 100wrms and the comps i bought are 80w nominal...
M6mkII12 = //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif
You can bridge your amp but isn't is going to output more than 100w in bridged mode?
SVTLightning01
SVTLightning01
San Diego, CA
SVTLightning01
michigan born
    May 14, 2026
michigan born
    May 14, 2026
