12" Dual 2 Ohm M3 MOJO Series Subwoofer Power Handling: Peak: 2000 watts RMS: 1000 watts Impedance: Dual 2 ohm Kevlar reinforced paper cone High-density foam surround Custom-cast vented "M" Basket Bolt-through modular motor for easy repair Orange finish Dual 2 ohm voice coils 3" Black anodized aluminum 4-layer voice coil former 228oz. Magnet Sensitivity: 90 dB. This is the best info I can find about the subs.
Class D
Power (watts) Mono 2500 @ 2 Ohms
Remote Bass Control Yes
Length (in., cm) 27/1/2, 69.7
Common to all Models Height: 2-1/8", 5.4cm Width: 9-5/8", 24.4cm Frequency Response: 25-200Hz (ZX300.1 25-20kHz), +0/-1dB Input Sensitivity: High Level 250mV-10V, Low Level 125mV-5V Signal-to-Noise Ratio: >95dB, a-weighted, re: rated power Active Crossover: 24dB/octave, variable 50Hz-200Hz (ZX300.1 fixed at 80Hz), low pass only 24dB/octave high-pass subsonic filter fixed @ 25Hz KICKEQ™ Boost: Variable to +18dB (ZX300.1 selectable +12dB), centered @ 40Hz
