adixon816
While getting ready for my new system I've decided to do the big 3. I read that you can just add-on to what's already there as far as factory wiring. I would likely replace the factory ground though from battery to chassis because it's such a wimpy wire. If I were to add on the power wire to the alternator would it make sense to put the 0g connector under the factory one so it'd be on the bottom of the two wires or does it not make a difference? The chassis ground just goes right to the body - figure I'll make sure it's touching bare metal. The last ground I don't really understand do I just pick a bolt on the block (somewhere recommended alternator bracket) and ground it to a different bare metal spot on the chassis somewhere? What do you guys recommend for terminals? My factory terminal already has two power wires on it (I guess from alternator and to the little fuse box) this is a 98 Explorer if that makes a difference. I basically just want to get my bearings straight and do it in one shot and right the first time.
