Need quick help on removing Accords center dash panel...
Freestyler717
Need help removing the panel which goes from the bottom of the 2 middle air vents the the windshield. What tools do i need and whats the procedure.
I don't wanna just pry it because it will ruin/dent the dash.... accords have that soft-ish plastic that dents.
Thanks, i wanna try to do this before the sun goes down.
i took a small flathead screwdriver and from the back pryed it up, its all held on by clips, then once the back is pryed up, work your way to the front, be careful not to break the clips. the first time is frustrating, if you use a big screw driver, your gonna make dents. i have a few from when i opened mine up for the first time. but you can barely see them unless you look straight at it.
My 3sixty was installed there. I had a problem with the unit, they reinstalled it but didn't tune it because you need a palm pilot. I have a palm now and want to tune it, so i need to get to the unit.
Im going to use a small flathead along with a putty knife. Putty knife to protect the trim, will use both in tandem.
...check out this tool. It would have been perfect.
http://akamaipix.crutchfield.com/products/2007/042/h042DM4022-f.jpeg
ya it would, goodluck
Holy gosh. This is harder than expected... Should i do one side first, then pop the other side, or should i go left right left right. ITs hard to get the back part because of the window.
What is that little round button-ish thing closest to the window?
Once i get it popped, do i lift the front up. (aka, back hinge) or does the whole thing come out?
Any other tips? Im having lots of trouble.
Freestyler717
Freestyler717
Los Angeles, CA
Silver
BP1Fanatic
BP1Fanatic
