Need quick help on removing Accords center dash panel...
The red part is a separate piece correct... they're not connected as one right (aka green)?
Right now I am trying to pop the red part only because thats where the unit is under. I didn't watch the install so i don't even know what im doing.
Don't be a *****, use a fibre stick and pop it out of there.
I have done many on caddys and such. did you try below the vents and work your way up uet?
Also if you think its a one piece stick a light thru the crack and see usually you can tell right off the bat.
Freestyler717
Freestyler717
Los Angeles, CA
Silver
