Need Prof opinion on this please.
BTW how far from anderson are you??? thats where i am. i can help better if you need it in person. for free unless of course i were to actually be hooking it all up.
dual coil. I am located in Greer. Everything like amps and all are hooked up, only thing i would need to hook up is the sub in the box. But yah that would be great if you would like to help me out, i can do it anytime tomorrow after 3:30
ok if its dual 2 then hook it up like the diagram you posted to get a 4 ohm load. when you get the second one wire it up the same and then your amp will see a 2ohm load. if you have any questions after that or whatever just pm me your number and i'll try to call and talk you through or something. if you still feel you need help you can come here and i can double check it all for you.
Thanks you sir very much, i apperciate much, now i know what to do. thank you for your time and patience:)
fastball11
fastball11
Greenville, SC
fastball11
