need help with wiring subwoofers
I guess you're going to want to wire parallel/parallel.  Theoretically that will have the amp at .75 ohms, but realistically it will be much higher most of the time (ac reactance vs dc resistance) so hopefully the amp runs ok.
Resulting load will be .75 ohms instead of 1.
I like to play it safe with impedance. I'd rather wire the dual voice coils in series, for 6 ohm per speaker, then wire the speakers in parallel to the amp for a 3 ohm load to the amp. Yes, you'll lose some wattage, but I'd rather not risk it unless you've seen that amp handle a .75 ohm nominal load.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
419
Riley Garcia
Riley Garcia
Mooncatt
    Apr 26, 2024
    Apr 26, 2024
