Need help with wiring. Subwoofer to amp.
cchheett
Oregon
I will be getting a system for my truck soon. I am going to buy an amplifier "HIFONICS BRUTUS BRZ1200.1D". I will buying 2 4ohm dual voice coils subwoofers. I will be hooking the subs up using a parallel set up.This will be a 2ohm setup. Here is a diagram that i understand . But the amp I will be getting is a mono amp. but it has 4 places to hook the subwoofers. Im not sure where do i hook the 2 wires that i would have left over after hooking the subs to each other. I'm sure there not bridged etc. I'm very new to this stuff so I know that what im trying to saying might be confusing. Thanks for any info. View attachment 26536029
First, If they are dual voice coil subwoofers you can't wire them to 2Ω, that diagram is for single voice coil subs. You can wire dual voice coils to 1Ω or 4Ω.
Second, on a mono amp there are two +'s and two -'s, but they are connected internally. If you were to wire two subs to a mono amp, and connect each sub directly to each of the outputs on the amp, they will be connected in parallel. So, if you look at the diagram, you wouldn't need wires going from one sub to the other, instead both subs would connect at the amp and the final load will be the same.
View attachment 26536032Thanks for the help. I still am a little confused. Is this new diagram what i should be looking at now."picture" The subs that im contemplating are Sundown audio E series. If i was to buy 2 E12 Dual 2 Ohm Subwoofer . I want to get a 2 ohm load of the amp.
why would u want a 2 ohm load... that amp is 1 ohm stable which means more power for you, wire them like vaiboy already stated, both of them directly to the amp and it will be a 1 ohm load 500ish watts per sub
The subs that im going to get are 400 each rms. The amp says its 900 watts at 2 ohm. The amp says 1200 watts at 1 ohm. I'm not sure if is should do 1 ohm. As everyone can tell im new to this.
I'm going to check out those links just posted. Thanks everyone for helping.
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Is that 1000w max? Don't expect to be able to bridge a 1000w amp at 2 ohms and get 500w x 2ch. I'm pretty sure you can't with that amp, for...
I am considering upgrading the sound system in my 2013 Ford F150. I have identified three potential head units: the Sony XAV-9500ES, the Pioneer...
cchheett
cchheett
Oregon
GreekBrotha8
    May 16, 2024
    May 16, 2024
