need help with a 18 box for trunk of a impala.
  • 4
What year Impala? Most likely be sub up and port to the side though...or sub up and precision ports to the back.
its a 2005 impala(old police car) i can fit 34 wide 16 tall and28 deep i was told but i think i can do a lil bigger than that.
Those dimensions would net you about 5.5 cubes (double baffled) with average amount of port area (12 per) at a 33hz tune give or take a little........
I did some measuring and figured out I can get a 15.5 tall 30 deep and 36 wide that's 8.39 cu ft I'm gonna use that as my box size. Should I go ported or can I use the 2 4in aero ports from last box.
you want more port area than that. can you use part of your spare tire well for the extra few inches of height you need? thats how i have an 18 facing forward in my civic.
I was told that I should have a 10 in aero port for the sub but I really just want a slot port sub up port back. I just need to figure out all my cuts and how to tune the box right.
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
4K
You can also set up your subs at 1-OHM. There are quite a few 5-channel amps that will do that, such as the Sundown Audio SAE-1100.5.
52
Also, it depends on the type of wire they installed. Copper will carry a lot for power than aluminum. How much power is your US Acoustic amp...
126
mtxfan4life
illinois
mtxfan4life
