*Need Help Bass Boost control
D3M0N
I have 2 Audiobahn Alum"12"Q subs....they are 12's
here are my specs on my subs and amplifier
Amp>
Features
High Current Circuitry
1-Ohm Stable: 2000W Into a 1-Ohm Load!
PWM MOSFET Power Supply
Double-Sided Glass Epoxy Circuit Board
Variable Parametric Bass Boost
Remote Bass Control with Blue Backlight Knob
Variable 24 dB High & Low-Pass Crossovers
Variable Subsonic Filter (20-45 Hz)
4-Way Protection Circuitry
Cobalt Blue Illumination
Blue LED Voltage and Status LEDs
VU Meters Indicating Output Response
Secondary Flame-Style Heat Sink
High Gloss Chrome-Plated Finish
Nickel-Plated Block Terminals
Dual Fan Cooled
Amplifier Type: Mono
RMS Power: 500W x 1 @ 4 ohms
THD at 4-Ohm RMS Power: 0.05%
RMS Power: 1000W x 1 @ 2 ohms
Speaker Level Inputs: No
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 18 dB
Frequency Response: 10-20,000 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: n/a
Subs>
Features
Optimized for Maximum Sound Quality
PHAT 1.75” EPDM Rubber Surround
120 oz. Magnet
Spun Aluminum Cone
Bolt-Tight Cast Flame Basket
Multi-Connect Lug-Lock Terminals
Mounting Depth: 5 5/8”
Hole Cutout: 11 1/8”
Outer Diameter: 12 3/4”
Rec. Sealed Box Dims: 0.50 - 2.00 cu.ft.
Rec. Ported Box Dims: 1.30 - 3.20 cu.ft.
Free Air Usage: not recommended
Sensitivity: 96.4 dB
Frequency Response: 18-500 Hz
Recommended RMS Power: 1000W
Peak Power Handling: 2000W
Impedance: dual 6 ohms subwoofer wiring options
I have these subs in a ported box...custom made at a car audio shop..they hooked everything up..
i would say that im running about 600 watts @ 3 ohms...to each sub....im not sure though..........
and i have a 5 farad blue legacy capacitor....and i thought that would stop the red blinking but it didnt .... i have know idea why the bass boost controle is blinking red or if it is bad when it blinks red...
The 1500 HCT is 2000 watts rms as long as u can deliver the power. The red that u see when it hits a slightly harder bass is the amp clipping which is not good. Usually its either the gain is set to high or even sometimes turning the bass boost down some is what i've been told.
do mean u each sub is wired in parallel to 3 ohms, if so they should each get 750 watts rms a piece since the amp would see a 1.5 ohm load since it's a mono amp?
Amp>
Features ...... Amplifier Type: Mono
RMS Power: 1000W x 1 @ 2 ohms .....
Subs>
Features ....
Impedance: dual 6 ohms subwoofer wiring options ....
well, from your first post it looks like you're:
A.) clipping
B.) suffering severe voltage drops
C.) running too low an impedance
D.) "Bass Boost" = "teh ghey"
E.) all of the above.
Those subs are dual 6. If each is wired at 3; then you have them wired to 1.5: you are prolly running under what ABahn rates them for (1kw@2ohm mono per your posted specs).
If each is wired at 3; then you have them wired to 6ohm: you prolly have the gain & boost cranked to compensate for the high impedance. Clipping.
You're amp wont putout 1200@3ohm (stereo). Nor will it putout 1200@3ohm mono. Nor can you wire those to drivers to a final load of 3ohm.
You specs state 2000max @ 1 ohm ; 1 ohm stable ; but only rated to 1000rms@2ohm.
Wanna clarify how You have it setup? Could probably help more.
In the meantime, turn down (or off) the bass boost and set the gains properly. Check your impedance load before you do though.
ok....i will check my setup when i get home.........so what your saying is...take the base boost control thing off...and set my gain higher...or lower.???
Yes, off with the bass boost and set your gain using the gain setting tutorial. But, by the sound of things, you'll likely have to turn it down.
listen to squeak... bass boost is very bad!!!
as ron popeil [of food dehydration/home rotisserie] would say:
"just set it and forget it..."
you can always make small adjustments from the headunit
once you get the gains where you want them...
//content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif at "set it and ferget it". and yeah no need for basss boost, it is a single band EQ, so if u are going to turn it up, make sure to do it before setting the gain, but no bass boot should be needed or used.
i cant help watching infomercials...
there is a newer one with knives!!!!!!
they give you like 36 knives or something... i was
watching with the GF and i predicted 22... man...
i didnt think it was going to get all crazy...
btw...
my 2 12" SE's will be here oct. 19th [tuesday]...
im dying for them... i ordered sept. 24th...
the wait is the enemy!!!
D3M0N
D3M0N
Petersburg, VA
g30ffr3y
