Need Feedback on my setup.
iHusk
Haven't been on here in a while. But getting a new car and redoing everything audio in it.
For Components I'm getting:
Amazon.com: Rockford Fosgate Power T152 5" Full Range Coaxial Speakers: Car Electronics ---- For the Front
Amazon.com: Rockford Fosgate Punch P1652-S 6.5-Inch Component Speakers: Car Electronics ---- For the read and Tweeters
Not sure what amp I'm getting to Power these, and input would be appriciated
For the Sub I'm either getting a 15" Fi BL or a 15" Alpine Type-R
Amazon.com: Alpine Type-R SWR-1542D - Car subwoofer driver - 750 Watt - 15": Car Electronics
Amp to power the sub will be:
Amazon.com: New Rockford Fosgate Prime 1200 Watt Class D 1 channel Amplifier: Car Electronics
Will either run the Alpine at 2 ohms pushing 800W or the BL at 1 ohm pushing 1200W
The Sub will be in a ported box, don't know what I will tune it to, need a little guidance on that. I listen to mostly Rap while the sub is on, would like high output from the sub so I can get plenty of thump, but at the same time don't want it to sound like complete trash. But for this SPL>SQ.
Will have Optima Yellow Top and HO Alt (Already in Car). Will have 2 Gauge running to amp and Ground.
Also Headunit I need some suggestions...I have a ****** JVC Single DIN right now, but would not mind upgrading to something a little better, any suggestions will be appreciated.
Seem like I have everything covered?? Any suggestions to make it sound better? Would like to keep near the price I am at right now, maybe 100-300 dollars more MAX as I am already sitting at about a grand without the materials for the box.
Theres no alpine amp lol. Its the Fosgate 1200 pushing the Alpine at 800W is what I meant to say. But is fosgate really **** for the amps? I've never liked their subs but heard their components were nice and have never heard bad things about their amps.
the prime amps are the low end amps =junk the speakers ok at best.you should put the components in the frt doors and coaxials in the rear tho.and if you look you can get better and sometimes for less.just remember if it's cheap then it's prolly junk .and dont listen to best buy or shops that sell cheap equipment.most will tell you its really good stuff when its not.so before you buy ask here what to look at and pay for .
Well the Type-R runs at 750 RMS and the BL runs at 1500 RMS, I can run the Type-R at 2 Ohms and the BL at 1 ohm. So there is your power. Budget wise I would say 300 bucks is about as high as I would like to go.
iHusk
iHusk
Omaha, NE
mylows10
