need designs for box
it is an 03 f150 supercrew...i want the ports firing up from the back of the box(or out the front if it is too hard up) and the subs facing the front but angled towards the roof
External dimensions:
WxHxD
47x24x19
.75 MDF
Add a second .75" front face
2 forward facing 6" dia ports 7.8" long each
9.98 cu ft @ 35Hz (accounting for port volume)
10.38 cuft gross.
Make sure you add brackets to screw the box
down. It will be top heavy and kill you in a head on.
External dimensions:WxHxD
47x24x19
.75 MDF
10.38 cuft gross.
wow that was fast...thanks alot i mean it but...and i know its my fault...i am wanting slot ports...if you dont want to figure that out then thats fine...sorry
47.75x24x19
.75 MDF
on the left or right add a 4" x 22.5" (box hight) vent port 9.71" deep
10.03 ish cu ft @ 35Hz (accounting for port volume)
10.37 cuft gross.
Mcsoul i cant thank you enough i would gladly send you some $$ for you time if you want...thanks alot
buck: i already did he cant atm
This is free, no warranty expressed or implied //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Make the vent 10" deep, not 9.71;
your net volume will be 9.868 after
port displacement, but not after woofer
displacement. Do you know what your
L7's displace?
If he doesn't want it I do!!//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
WxHxD
48x25x19
.75 MDF
Add a second .75" front face (this will make the box 19.75" deep)
10.05 ish cu ft @ 35Hz (accounting for port volume)
10.88 cuft gross.
Sorry, back to 9.71"
used .19 as each woofer's disp (it's a guess)
the port displacement is .505
woofer + port .885
box disp 10.888
Edit:
You know what, this (my)design is not structurally sound.
It needs internal bracing because of the front face not
going all the way across (due to the vent). That internal
bracing needs to be designed by a pro.
The round port box would be a lot easier to build.
48x25x19
.75 MDF
10.88 cuft gross.
woofer + port .885
box disp 10.888
Edit:
i had already planned on putting bracing in...it would look like a triangle...i am a carpenter and i know how to brace things //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Spectrum
Banned
Spectrum
Knoxville, Tn
Spectrum
