Need box plans for 2 10" Alpine TypeR's
Recommended sealed box volume = 0.55 cu. ft - 0.8 cu. ft.
Use a box building program to figure out the dimensions - you want to end up with .55 - .8 of internal airspace per driver.
- Steve
EDIT = You could always go a little bigger than the recommended box size //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
WinISD is free...search for it on Yahoo! and download it.
Dual chamber - 1 chamber for each sub, divider running right down the middle of the box...changes nothing(be sure to make sure your dimensions are right though, to get the correct airspace).
- Steve
I dont like running 2 subs in the same airspace because if 1 stops working, then the other sub thinks it is using not half, but all the airspace...which can cause harm to it. So I blow 2 subs instead of 1...
- Steve
Originally posted by ss3079 I dont like running 2 subs in the same airspace because if 1 stops working, then the other sub thinks it is using not half, but all the airspace...which can cause harm to it. So I blow 2 subs instead of 1...
- Steve
yup, thats what I was told also and why i decided to go dual chamber, thanks steve, appreciate the help
Originally posted by Beast1284 yup, thats what I was told also and why i decided to go dual chamber, thanks steve, appreciate the help
No prob...let us know if you need any more help, and how the box turns out //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
- Steve
Beast1284
Beast1284
Upstate New York
ss3079
michigan born
    May 14, 2026
michigan born
    May 14, 2026
