Need Box Design for 2 12" DD 9512g
Korn4Life
SUB LOVE
I have a two door 1996 Pontiac Grand Am... I have the backseat out of the car and will be firing the subs forward into the car with the trunk sealed off... I have Max Dimensions of 16" High X 37" Wide X 30 Deep... Can someone come up with a design with drawings and cut sheets... I would like it to be as loud as possible and still have a slightly ok sound to it.... I will be running the subs with two IA 40.1's I will pay for design if need be... Thanks alot for your help...
I dunno the T/S Parameters... Maybe someone else knows them or the website has them listed..... Sorry I just have the subs no instructions or specs
Here is what i got from there site
9500g
Voice Coil Diameter
3"
Magnet Weight
406 oz
Power Handling RMS/Peak
1500/6000
Suspension
80 mm
Nominal Impedance
.35 - 4.0 Ohm
DC Resistance
.35 - 3.6 Ohm
Model
9510g
9512g
9515g
9518g
Rec Box (cubic ft)
1.6
2.6
4.25
6
Port Area (sq in)
32
52
85
120
Port Length (inches)
18
18
18
18
Woofer Diameter
10"
12"
15"
18"
Free Air Resonance
35 Hz
34 Hz
33 Hz
29 Hz
Qts
0.25
0.31
0.29
Qes
0.27
0.33
0.31
Qms
3.1
4.15
4.32
Vas
15L
35 L
85 L
Sensitivity
87 dB
89 dB
93 dB
94 dB
Shipping Weight
50 lbs
51 lbs
55 lbs
When they only list three, are they leaving out the 10 or the 18?
Qts
0.25
0.31
0.29
Qes
0.27
0.33
0.31
Qms
3.1
4.15
4.32
Vas
15L
35 L
85 L
Based on the info, they are recommending a
5.2 cubic foot box tuned to 43 Hz.
Rec Box (cubic ft)
2.6
Port Area (sq in)
52
18
Based on the info, they are recommending a5.2 cubic foot box tuned to 30 or 31 Hz.
Rec Box (cubic ft)
2.6
Port Area (sq in)
52
18
So would the box be 5.2 cubic feet with 104 Sq in of port @ 18" Deep
No 5.2 plus 104 @ 18" or is that what you meant?
Let me run the numbers, looks like 3 4" areos will be
easiest to build. The tune I came up with was actually
43Hz
Korn4Life
SUB LOVE
Korn4Life
PA
iamamp3pimp
