need amp ideas for 4 sundown audio sa-8 v2
I am running 4 sa8v2's on a ampere audio 3500.1 prototype. The amp will be available to the public in a couple months max.
amp looks like the old rd amps
Its a prototype, I think the heat sink is from a rd. The production model will have a different heat sink and certain beefed up internals for greater efficiency! I can tell you Ampere is doing it right before they come to market. A lot of real world testing and a dedicated passionate owner
American Bass Ph4000md 4000w
POWER HANDLING:
◦ 2000W RMS @ 1 OHM
◦4000W Peak wattage @ 1ohm
• NO BASS KNOB AND THERE IS NO INPUT TO ADD A BASS KNOB
• 1 OHM STABLE
• VARIABLE SUBSONIC FILTER
• MONO BLOCK AMPLIFIER
• VARIABLE BASS BOOST
• FREQ. RESPONSE: 10Hz-220Hz
• 4-WAY PROTECTION (THERMAL, VOLTAGE, SPEAKER SHORT AND DC)
• VARIABLE LOW PASS FILTER
2 of these would work?
that is cool ,i like to hear that
POWER HANDLING:
◦ 2000W RMS @ 1 OHM
• 1 OHM STABLE
id use the vfl 4480 instead
how much is that 3500.1 gonna cost id look in to buying one
$700-800
Clamped wattage by Tantric Sounds (very reputable) 3960 watts@ 1 OHM @ 12.4 volts. Test from 9v-20v!!
I would buy Ampere before a American Bass personally. I looked into American Bass and spoke with them for a while at this years CES... I'll leave it at that
•Hifonics Zeus ZRX3000.1D Mono Class D Amplifier
•RMS Power Rating: 750 Watts @ 4 Ohms
•RMS Power Rating: 1500 Watts @ 2 Ohms
•RMS Power Rating: 3000 Watts @ 1 Ohm
•Illuminated Hifonics Badge
•High Efficiency D-Class Technology
•Hifonics Heat sink for Superior Heat Dissipation
•Military Grade PCB
•Ultra-Fi MOSFETS for low THD & Noise
•SPC - Simpatico Coil Design
•HSMD - Hifonics Surface Mount Design
•PWM MOSFET Power Supply for Maximum Current Levels
•Diagnostic Indicators
•DC, Short Circuit, Thermal and Overload Protection
•RCA Inputs & Outputs
•Mono Amp
•4/2/1 Ohm Stable
•Bass (Level) Remote
•45Hz Bass EQ
•Variable Low Pass and Subsonic Filters
2 of these do alright?
Hi what about Alpine MRP M500 - car - amplifier???? I think its best one.
he would have to buy 8 of those to get the power those 8's will want...
skippy, you could get away with one of those zeus for a while until you saved up for a better amp. look around the classifieds and see whats there...
856
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
skippy90210
skippy90210
ramey, PA
skippy90210
    Jun 1, 2024
    May 31, 2024
