amp looks like the old rd ampsI am running 4 sa8v2's on a ampere audio 3500.1 prototype. The amp will be available to the public in a couple months max.![]()
Its a prototype, I think the heat sink is from a rd. The production model will have a different heat sink and certain beefed up internals for greater efficiency! I can tell you Ampere is doing it right before they come to market. A lot of real world testing and a dedicated passionate owneramp looks like the old rd amps
that is cool ,i like to hear thatIts a prototype, I think the heat sink is from a rd. The production model will have a different heat sink and certain beefed up internals for greater efficiency! I can tell you Ampere is doing it right before they come to market. A lot of real world testing and a dedicated passionate owner
id use the vfl 4480 insteadAmerican Bass Ph4000md 4000w
POWER HANDLING:
◦ 2000W RMS @ 1 OHM
◦4000W Peak wattage @ 1ohm
• NO BASS KNOB AND THERE IS NO INPUT TO ADD A BASS KNOB
• 1 OHM STABLE
• VARIABLE SUBSONIC FILTER
• MONO BLOCK AMPLIFIER
• VARIABLE BASS BOOST
• FREQ. RESPONSE: 10Hz-220Hz
• 4-WAY PROTECTION (THERMAL, VOLTAGE, SPEAKER SHORT AND DC)
• VARIABLE LOW PASS FILTER
2 of these would work?
$700-800how much is that 3500.1 gonna cost id look in to buying one
he would have to buy 8 of those to get the power those 8's will want...Hi what about Alpine MRP M500 - car - amplifier???? I think its best one.
I have a quad 8 box. 1 cube each, two seperate chambers, tuned to 33hz.is there anyone that could design a box for me that would run the 4 subs? i could build it if i knew what to build
