need advice on my new box
  • 4
frogcase2002
Looking for tips on what else needs done to complete the box in my trunk if anything, its for my 15 zcon, 4.4 cubes tuned to 32, built it in the trunk then have one layer of fiberglass on all corners, just seeing if anyone sees anything wrong or anything to add to make it better,, and you think i should put the sub on the baffle before i put it on the box or what
why did you use fiberglass may i ask
i just had alot of resin and mat and stuff from another project im working on and figured it would make it stonger and make the corners more rounded, anything wrong with using it?
By no means am I an audio expert like some members here. With that being said I once read a thread were a member suggested placing a vacuum cleaner hose on the box and observing the air that is able to be pulled from the inside of the box. They then suggested placing a small coat of resin to the entire inside of the box to prevent any lose. Makes sense I suppose? But again, Im no expert..
Well you have definitely sealed your trunk off backwards
yea kinda looks like it but there is probley at leat 6 inches on each side and i took the spare tire out so there is a pretty big opening under the box from in front of the box to almost all the way to my back seats that fold down
609
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
694
Man, sounds great - no pun intended! Glad you're happy with those Morels, I think they are special. Not sure why they don't get the local love. I...
36
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
941
frogcase2002
frogcase2002
hamilton, ohio
frogcase2002
    Jun 15, 2024
    Jun 15, 2024
