Need a new wiring kit
Strangirs
Hey guys,
I haven't done car audio in ages. I currently have a Skar RP-1500.1D and a Skar RP-75.4AB. I tried cheaping out and got an Installbay dual-amp kit which I regret. The person that installed it said that the wire is junk and that It's arching. Originally the fuse near the battery blew and I replaced it and it was fine for another month.. The four channel still works, just not the mono. I am wanting to look for a permanent fix for this on a budget. Looking at the amp ratings I feel like 4 gauge is too small, but that's what it fits. I currently have a distro running one gauge to four gauge.
I really want to get this fixed for under $100 preferably. I've been looking at OFC options below. Let me know if these will work or what better options there are!
http://www.knukonceptz.com/mobile-a...olossus-fleks-kable-10-red-power-ground-wire/ (get ~28 feet of this and use the distro block I have and fuse..)
Any ideas would help!
So what exactly do you need? Just some wire to go from the D block to your mono amp? A fuse block as well? Or you are replacing everything?
Knukonceptz is my favorite as far as wire and rcas.
Mainly looking to replace just the wire from the battery + d block. It seems that the wire is fine near the amps, but near the battery it's burnt up. (previous cheap kit fuse holder melted), which is now an ANL. I understand I'll likely have to replace the fuse again, but seems like Knukonceptz will do the trick.
Would four gauge be enough? Or should I opt for 0 gauge to 4 gauge distro.
Strangirs
Strangirs
Chicago
Mike Mccabe
