Need a little help Pleeeze - long
Tib2k3
K, heres what I have (or in the middle of getting):
2 12L7's
1 jbl1200.1
1 jblp80,4
1 DLS MS6 comps
6ft of 4ga, 0ga pos and neg terminals
Lots of 8ga, old rca's and remote wire (from old amp)
So I need to assemble an amp kit and i need to upgrade the big 3, Ive got in touch with a guy and bought this( it was more, but ive changed some of the other stuff, cuz i already have it) :
18ft of 1/0ga Streetwires Red Translucent power cable w/ crimp ring installed
4ft of 1/0ga Streetwires Silver Translucent ground cable w/ crimp ring installed
(1) Streetwires inline 1/0ga ANL water proof fuse holder
(1) Tiff fused distribution block w/ (1) 1/0ga input & (4) 8ga ouputs
(4) maxi fuses (2) 80 amp & (2) 40 amp
(1) Tiff ground distribution block w/ (1) 1/0ga input & (4) 8ga ouputs
(2) 10ft sets of Tiff TCI-1000 RCA Interconnects (slim profile for easy installation and routing) or (1) set of MTX 20ft twisted pair RCA's---- Please specify which RCA's you will need.
(1) Streetwires 200 amp ANL fuse (I also have 80, 150 & 300 amp Tiff ANL fuses)
(1) Rubber firewall bushing
This is what else he has:
ANL digital fuse block (Tsunami brand) (1 1/0ga in)(2 4ga out)
Voodoo ANL 1/0ga digital fuse holder that has (1) 1/0ga input & (1) 1/0ga ouput
I have 1/0ga wire on a roll (black solid MTX, blue & red ***** Lighting Audio)
4ga wire (red ***** Streetwires, small amount of blk ***** Streetwires & gray solid Tiff)
20ft MTX, 10ft Tiff,12ft Streetwires 2.0 Fosgate (Matrix) 9.5ft, 6ft & 3ft RCA's
1/0ga inline ANL Streetwires, Tiff & MTX fuse holders
4ga AGU (glass fuse) Tiff & Streetwires inline fuse holders
Tiff & MTX fused (Tiff is the one with the (1) 1/0ga input, (2) 4ga outputs and (1) 1/0ga ouput) distribution blocks and ground distribution blocks.
1/0 ga crimp rings,
1/0ga interlocking rings (set screw type)
4ga interlocking rings (set screw type)
8ga crimp rings
speaker wire (thinks it's 16ga) free
twisted 12ga speaker wire with a protective outer cover
I also have quite a bit of misc Fosgate fused (AGU, glass fuse) distribution blocks
Did you want some extra 1/0ga wire for the big 3 or
were you going to use some of the Streetwires cable? I
don't have any crimp rings at the moment but if you
know the length of cables you will need for the big 3,
I can cut the wire, buy the crimp ends and crimp them
on for you (I have a really nice heavy duty crimper).
I will only charge you for the crimp rings, not to
crimp them. What size (5/16in or 3/8in) of eyelets did
you need?I also
have two Fosgate 1/2 farad capacitors (they are used
but in near perfect condition and have one capacitor
block (mounts to the top of the capacitor) for the top
of the capacitor (has multiple inputs and outputs).
These are not a necesity but if you want, I will work
out a good price for you
Sorry for da huuuuuuuuuge post //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif
For the big 3, do i need 6 crimp rings?
Thanks 4 annnnnnny input //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
(going into a 03 tiburon, relatively small coupe)
Tib2k3
Tib2k3
Lakeland, FL
JaysonR
