Mix and Match Help
baja newbe
I'm installing a new stereo in our boat and could really use some help.
Lets start with what I have:
1 Clarion M475 Marine Head unit.
2 New Audionbah aw1006t Flame 10" 4 ohm dual voice coil subs.
1 New Audiobahn A4801T 1400W RMS 4/2 Ch Bridgeable Amplifier
1 Used Kenwood KAC-818 Amplifier Mono Channel Not Bridgable RMS Power at 2 Ohms 300 W x 1 RMS Power at 4 Ohms 200 W x 1.
1 Used Rockford Fosgate Punch 600 4 channel amp 75X4 in 4 ohm, 150X4 2 ohm, Bridged 300X2 4 ohm.
4 New Sony xplod 6.5" 3-way XS-V1630 65 watt RMS.
2 New Piezo tweeters 200 watts RMS.
I understand the big three and have wired several basic stereos, but I could really use help with wiring the speakers (2 ohm/4 ohm, which amp to what speakers) I was thinking I would probably only use two amps but any suggestions would be fantastic.
I would probably wire the 6.5's to the rockford amp, one to each channel. Bridge the audiobaun amp to 2 channels and wire the subs one to each channel at 2ohms if that amp will handle a 2ohm load bridged. If not, wire the subs together at 4ohms on one of the bridged channels of the audiobaun. If you need to know how to wire your subs to get the load (ohms) you need check out the sticky at the top of this forum.
baja newbe
baja newbe
Omaha, NE
Bake
