need a box design...by this weekend
It depends on the box for me.But personally I lay the bottom down, do the back, sides, front baffle, then port (if it attaches to the front baffle) and so on and I end with the top.
Just look at the design and you can get it.
i always do exactly what mountaineer man said; and you don't have to screw; i'd invest in some good clamps.
or, if you don't have clamps, do what i used to do. put the bottom board on a table with the back lip hanging over by a 3 inches or so. glue the back piece and set it where it's going. with the help of a friend/relative/whoever, screw it in. sit down and screw up, while your friend pushes down on the board and keeps it lined up. put a brick/weight on the front lip of the board, to help weight distribution.
how you build really depends on the design...
I did one similar HERE
BTW, I would have gave you a 3d build sheet if I designed it, typically by request;)
dvrmstrng
dvrmstrng
DE
rpfuror
