Need 12" 4 ohm sub pair with 300W Class AB
It is not clear if 300watts is for the pair of subs or just one. Anyways, I'd consider an Infinity Kappa 120.9w in a 1cu ft box if you can give >300watts to each. It's a good all around subwoofer, with excellent SQ and will handle a bit more power over its rated IMO. 1 to 1.2cu ft cubes is about perfect for it. It has fine SQ to my ear. Very good value. If you can afford a more expensive subwoofer consider Image Dynamics IDQv3D2 or Peerless XXLS 12 from parts express. Both have very good sensitivity and baddass SQ. Peerless should be ok in 1cube, but I'd recommend to give it as much space as you can afford, maybe 1.3-1.5 cubest. Peerless will be the loudest on just 300watts among the three, but IDQ should play louder and with more composure once you give it it >500watts of power.
Hi zako, this is for just one 12" sub and I'm able to give it only 300W @ 4 ohms from the JL 450/4.
The reason why its not a good idea to underpower a sub is because you will be tempted to give it bass boost or turn the gain up higher than it should be, which leads to clipping which puts excess heat on the voice coil leading to failure.
that is a by-product of clipping. If the temptation exists to do as you say, then it matters not what sub is used. The Nak would be perfect for op's needs. This Idea of under powering hurting any speaker is simply ignorance in this case.
Hi quackhead,I think this would be an great choice if I had more juice to power it, But since I'm limited to 300W this probably wouldn't work well right?
In this forum I believe I've seen that under-powering a subwoofer can be just as bad as way-over powering it....
It would be perfect for your application. The amount of power you have will not hurt a thing. If you feel the need to clip your amp, it will not matter what sub you use. If more output is desired, you will need a bigger amp, more cone area, or both.. no matter what. There is no reason that the Nak would not work perfectly with the amp you have. It is not designed with the soft parts that are too stiff for SQ use such as some of the big, beefy subs designed to handle thousands of watts in SPL competition use. Do not let the ignorant who say a 600 watt sub won't work with a 400 watt amp fool you like that.
There's still some time before my installer is available (In November) but I think you have convinced me to go with the Nakamichi. I may get a AQ1200 to go with this sub in the future.
If you go witht he boston sub which is amazing, i have a passive radiator for it so you would only need a 1 cube box with the sound output of a ported box. also will save on the box since building a sealed box is easier.
Boston Acoustics GTR12 TunableRadiator (Black) 12" passive radiator for use with Boston G5 subwoofers at Crutchfield.com
40 shipped 2 you, they are amazing
Soundster
Soundster
San Francisco, CA
trumpet
