Sub help pioneer shallow subs
Fillerup
Hello was just wondering I have 2 TS-SW2501S2 2 ohms subs an a class d pioneer GM-D7500M mono amp with a Sony explode cd deck was wondering whats the best way to wire them I was told so many different ways I want them to pound what do I have to do I'm new to all this
Unfortunately, you cannot use that amp to its full potential. It is only two ohm stable. Having two 2-ohm subs means you will end up with either a 1 or 4 ohm impedance, depending on how you wire. You cannot wire at 1 ohm to that amp, or you will burn it up.... so that leaves using it at 4 ohms and only getting 200 watts out of it. It might be louder to use one sub and get the 400 out of it at 2 ohms, but that would exceed the rms rating of the sub, so you are better off just using both and wiring them in a series.
Wire them like this:
images
edit: I would recommend selling/trading that amp for one that makes 600 watts rms at 1 or 4 ohms..
You can look around the classifieds for good deals, but if you must buy new, a hifonics brutus 1700 puts out 600w at 4 ohms and you have plenty of headroom to upgrade in the future
That looks like good one is it worth the money or should I shop around
or
http://www.caraudio.com/forums/amplifier-classifieds/557171-fosgate-r-1000d.html
Specs:
•PRIME Series Single-Channel Monoblock Class D Car Amplifier
•RMS Power Rating:
◦4 ohms: 500 watts x 1 chan.
◦2 ohms: 1000 watts x 1 chan.
•Pulse Width Modulated MOSFET power supply
•LED power (green) and protect (red) indicators
•Variable Bass Boost (0-12 dB bass boost at 45 Hz)
•Single-channel operation
•Wired remote bass level control included
•Preamp RCA outputs to daisy chain multiple amps
•Heavy duty extruded aluminum alloy heatsink for optimal heat dissipation
•Dual speaker terminals simplify the hookup of multiple speakers
•Nickel-plated RCA level inputs
•Nickel-plated screw terminals
•Input sensitivity:
◦Level: 150mV-8V
•Variable low-pass filter (40-130 Hz, 12 dB/octave Butterworth)
•Damping factor: >200
•Phase Shift: 0-180°
•CEA-2006 compliant amplifier
•Frequency response: 20-130 Hz
•Dimensions: 7-11/16"L x 12-1/8"W x 2-7/16"H
•4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
Thanks everyone for the help that Hifonics amp was looking at the specs and it can be bridged down to 1 ohm could I do that to make them sound better
If you parallel your subs down to one ohm on that hifonics amp, the amp will no longer put 600w to them, but will instead give them 1700w and blow them to smithereens. Either get a big amp and wire into 4 ohms. Or get a small amp that can do 600w at one ohm.
Fillerup
Fillerup
PEI CA
jungstah
Mike Mccabe
