need .05 ohm amp suggestion
the old soundstreams claimed to be stable at any ohm load
I had a referance 500 and a rubicon 405.The 405 didn't play below .5 on the sub channel and the referance didn't like anything lower then .25 and that was for a very short burp.
.5 on any amp daily is hard.I wouldn't recommend it to anyone for daily.Most amps that can take it will thermal if you really beat on it hard constantly.
I've been running a pair of Powerbass asa 1000.1D at .5 ohm daily for quite awhile now. 1/4 ohm at comps.
Edit, 60 amp alternator, 1 run of 0 gauge and 2 Kinetik 1800s
your better off with a 2ohm amp if you dont how the power to surply it if you dont know whats going on i wouldnt run .5ohm amps daily
^^^ He's right, The only reason I run mine like I do is I ain't afraid of smoke.
When you say power to supply it, it leaves myself (and I'm sure others) curious just what is required.
a) Enough alternator to keep everything at 14.4 or nearly that.
b) Enough battery backup to prevent voltage drop down to 11.5 or so
c) Enough alternator to keep the batteries charged well enough
d) b) and c) together
For the AB, Sundown, etc 3kw amp, what is "good enough" to drop down to 1/2 or even 1/4 from everyone's experiences.
(thanks alvitae for mind-reading)
I've been running my 1606D at 0.5 ohm daily for 2 months now on stock electrical. I'm hoping imp rise will save my *** but I'm expecting it to give off that lovely smoke any time.
Are you sure the Lanzar is stable to 1/2 ohm? I heard before my Planet Audio TT2250D had the exact same board, and that was only stable to 1 ohm I think.
dirtysouth31
how much?
dirtysouth31
twisteds butthole
Sarthos
