need .05 ohm amp suggestion
if i wire my subs in parallel the amp will see 1/2 ohm..if i leave at series than it sees 2 ohm..its a hifonics brutus bxi2010d..its says 1300 at 2 ohms and 22oo at 1 ohm..but the sub is dual 1 ohm coils..which means if i want to pull more power out the amp to sub i would have to wire in parallel..all pos together and all negs together right
If you do that to the hifonics it goes poof. You don't NEED an amp that will do .5 daily, that is hard on an amp, and you obviously don't have enough experience to set up or maintain a system like that. For you, I would definitely recommend looking for your power need at 2 ohms.
dirtysouth31
how much?
dirtysouth31
twisteds butthole
Sarthos
