yes this willl be great. As far as ur question about the ohm load. the 8A only comes in dual4 ohm. So it could not be wired to 4 ohm load to bridge an amp. But if u can get a Dual 2 ohm sub then u could wire the sub to the amp and bridge it to a 4 ohm load.Wonderful suggestions. Thank you.
Front speakers: I was considering that if I get rid of the rear fill, I might pay the extra $50 and get the CDT HD-62CF components. Is the upgrade worth it, or will the difference be negligible?
Front amp: I have a question. You pointed me to an 80W amp instead of a 100W one (the CL-61a’s were rated at 90W, right in the middle). Obviously, I neither want to underpower or overpower them, but when the difference between the speakers’ power rating and the power I’d be giving them is so small, should I opt for a little above the rating or a little below? The HD-62CF are rated at 130W RMS, and I’m looking at either the Profile CL400 (100W x 2) or CL600 (150W x 2) to power them.
Rear fill: If I have none, will the passengers in the back seat be at a disadvantage? Will the lack of speakers in their doors sound strange to them? Is everyone here without rear speakers?
Sub: Thank you for the confidence. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Sub amp: That looks very nice. I think I’ll be getting it instead of the Fosgate.
Will this system sound blanaced? One 8” sub under the front passenger seat, and a set of components in the front? I don't want to have loud bass and weak midrange, or anything like that...
Besides that i would get the high definitions, suposedly they sound amazing, they look freakin sweet too. As far as powering them, i have cystal components which are rated at 65rms and i running 100 watts to each Xover. I think its better to overpower the speakers cuz its easy to turn down ur gain and control power but its not easy to get an amp that under power and push it hard to put out more power than it can handle.
