My sub is coming out of my box
Buck
little alien on campus
well after playing it for a week, my sub is in the process of strippin the screws out of the wood that are holding the sub in. its 3/4 mdf, and they are wood screws.
i was going to put another sheet of mdf on the front, and cut another sub hole and then get some 1.5 inch wood screws and see if that would work.
if anyone has any advice i would appreciate it.
put the sub in the right way to begin with.. ditch the wood screws.. line up your holes, drill holes to fit tee nuts, insert tee nut into hole, fill around it with liquid nails (optional), find matching bolts and screw them in.. believe me it will stay put.
proper wood screws will not let loose unless they are over tightened
do NOT use a drill or a power screw driver to tighten up the sub mounting
screws...they only need to be snugged by hand
T Nuts work well but they strip just as easy as MDF if they are over tightened
and when T Nuts are used I would recommend gluing the suckers in..
sometimes when T Nuts are used it is possible to push to hard on the screw
and the T Nut will come loose inside the box and free spin..it can be a real
pain in the AZZ to get them loose
proper wood screws will not let loose unless they are over tighteneddo NOT use a drill or a power screw driver to tighten up the sub mounting
ya and with screw driver yuor less likly to miss and make a hole in the surround:mad:
hmm i have never slpped off a screw iwth a drill or a screw driver im really cautious when screwing them in whe i use a screwdrive i wrap my hand around it .. whne i use a drill i go slow and put my hand flat between the screw and sub..
Buck
Buck
Inside of a pyramid
mcsoul
