My SK-1500.1 is junk
Kevin told me to send to amp medics, so i did. He said he fixed whatever problem it had and then lone behold less than one month after being returned its starting to act up again. The repair costed $135
"lo, and behold" lone behold sounds like you got your **** in your hand
well good to hear yoru shizz works
I bet this thing has a conscience and knows when to make me look an idiot/go insane
ON a side note, if it happens to go off every once in a while, ill just go to radioshack and fabricate a makeshift switch in the remote line and stick it under the drivers seat. That way with a push of a button i can reset the amp if it decides to shut off
AND another side note, maybe @SkarAudio could answer this. Could the LC2i having 9v preouts have anything to do with this?
check your head unit and line driver grounding/power. maybe use a y-splitter and check with meter and scope while playing. head unit or mids amp filtered high enough for no bass distortion, or tuned for no distortion otherwise? not sure on the amp in question, but many do enter protect with an rca dc offset/load. exactly what was repaired before?
Vibration damage due to mounting the amp to my box
I had an LC2i in my Infiniti for awhile before switching the the LC6i, and the LC2i gave my SK-1500.1 no problems, protect, etc. It should be fine.
What was your bass/gain settings on the unit? I have accubass turned off and the gain about 10oclock
According to Crutchfield, those JLs won;t fit in your dash, can't see why, just what it says on their site. it says those JL's won;t fit in the...
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
446
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
680
Well, there is always a bypass that can be McGuyvered. So next time you want to tackle that task, post it. We can help.
All you need. I've been running these for years in 3 different vehicles. https://www.amazon.com/dp/B01BL57JO2/?tag=caraudiocom-20
936
JoeK
JoeK
Ringtown, PA
gckless
    May 31, 2024
    May 24, 2024
