my ported vs. sealed thread.
yes port the w3's but tune it low and they will sound sweet
80
I have the plan to build a wedge shaped slot ported enclosure tuned at 32 Hz //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I think it's a good sql tune frequency, what do u think?
//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif
I think you got confused on which box size for each application, 4 cu ft ported and 3.5 cu ft sealed makes a lot more sense.
nope i got it right--2 cf per sub sealed is the max recommended by the manufacturer, and JMAC from this forum designed my ported box based off of my space constraints and the manufacturers specs.
You are both wrong and right, first it depends on the freq or the kick drum, some are lower and some are higher. If you have the midbass/subbass blended together and the phases of the different speakers correctly matched to the ear you will have a hard time noticing where either is coming from. forgive thy spelling
Sorry man ... I couldn't get anything that looked good ... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif IIRC, I went with the maximum amount of internal volume (~3.5 ft^3) you had and the same tuning because it was only slightly less volume than the manufacturer's recommendation ...
Mechanical power handling should be much worse in the 2 ft^3/sub sealed enclosure ...
i got no problems with the box you designed---as a matter of fact it sounds great. i just decided to do a nice trick set-up and thought i would experiment along the way. I'll be building another ported box tomorrow that will fit the space i decided on.
bonesninja
bonesninja
Lima, Ohio
bonesninja
