my box design for a hdc3 (when they are released)
littledude
MI
well as soon at this sub comes out im gonna order it. im getting one 15"
the box i was thinking about making was
H=27
W=36
d=19.5
the port is 5.8in wide
tunes around 40hz
a gross volume of 11 cu.ft
i am going to have the port pointed back and the sub pointed upwards.
its going to be going in my jeep. right now the amp i have for it is a Brutus bxi2006d but depending on how it sounds i may go bigger.
will this be a good setup??
Seems to be on the big side, but you could try it and see how it works. I prefer 4.5cubes @ 35Hz for daily. 38Hz was a little peaky/boomy, but if it listen to mostly rap then the higher tune should be fine...
well im upgrading from 2 type r 12's i want to be louder even if its just by a little, i will probably end up putting it in a 4.5 cu.ft. then, but i don't know where ill tune it yet.
littledude
littledude
MI
KnOkIn It 420
michigan born
    May 14, 2026
michigan born
    May 14, 2026
