my 16 10s design
nuboot
well heres my first ever design using sketch up each of the sides are 26h x 15w x 45d for 8.3 cubes
and the opening area will act as the ported area and the measurement to the area is 26h x 25x 45d so iits about 650 square inches of port area and tuned to around 43 hz
so does that look and sound right
hopefully this box hit the lows do a possible hair trick and still put up decent numbers
a 4th order bp is one side sealed one side vented
http://www.diysubwoofers.org/bnd/4thorder.htm
the sealed are behind the woofer on the right and left are the sealed section and the long "tunnel" is a port 26"x25" right being 45 "long that is the vented side
toss the t/s parameters in winisd or a sub program and see i bet its tuned really low like 15-30hz thats just a guess though
the two boxes 1 on the left 1 on the right they are sealed and the tunnel part with the loading wall is supposed to be the ported area. i guess thats what u just said. im confused now lol
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
nuboot
nuboot
lawton, ok
nuboot
DEW123
    May 7, 2024
DEW123
    May 7, 2024
