multimeter setting
1. where are you taking the reading?2. how many watts is the amp supposed to put out at max volume?
1) i am taking the reading outiside in the trunk of my car.
2) the amp is a hifonics 1500BX and at a 2Ohm load its supposed to give out 1000rms (maybe overrated but thats what i am goin with).
so basically i am lookin for this number to come up on my mm when i put it on volume 22 (my personal max) : sqrt(1000*2)=44.721...
(this is with the 50hz in the h/u)
however what i keep reading is something in the .3** V
i have tried a couple times already yet no good results
maybe its the 50hz track i am using. can any one help me out?
1) i am taking the reading outiside in the trunk of my car.2) the amp is a hifonics 1500BX and at a 2Ohm load its supposed to give out 1000rms (maybe overrated but thats what i am goin with).
i think he meant where are you sticking the probes, not where you physically are lol
well i guess then the only thing left to try is a different 50hz track and then im just goin to return it and try another mm.
anyone know where i can get a cheap oscope. i tried googling it but it took me to all these high tech sites which have all sorts of expensive oscopes. Not too sure what to look for either.
Maybe the amp isn't working? Hook up your subs and set the gain by ear first. 50Hz track on a CD is correct. Make sure you have the lowpass mode on, with freq set for 70-80 Hz. Set your HU at 2/3 and turn up the gain slowly. Subs should get rather loud. Then unhook the subs and connect your DVM to the wires for the final setting.
ndnbolla
Jigga what?
ndnbolla
paradise
sumone
