MTX Thunder 81000D is Blown.. Sell it? Fix it? or Trade to MTX for TA7801?
i blew mine (1501d/same thing) and 2002xlt got it in a trade for a pair of tens he had.
he sent it in and said most everything was shot! lol. because of loose rca's //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Counting from the top right of the pic. The 1st, 4th, and 8th FETS are bad. It also looks to be tiny resistors below the 4th and 8th fets. They look burnt also. I don't know much about this kind of stuff but everything else looks fine.
that should be a fairly cheap fix. the caps aren't swollen so thats good.
how did you kill it?
I hooked it up and the light came on. So I was happy about that. I didn't have a manual at the time and I'm not familiar with how these amps work. I hooked it up 2ohm on 1 channel. The volume was kinda low(not much bass). I knew It was 2ohm stable. So I bridged it at 2ohms. I now know its only stable at 4ohm bridged and 2 ohm stereo or whatever you want to call it (these MTX speaker connections are not what I'm used to). It worked for about 20 minutes at medium volume. It just stopped working and a little bit of smoke.
The amp still powers up just no sound.
thats dead wrong bro. no offense.
this is a mono amp (1 channel). what you see as 2 ch is just the ease of hooking up more than one sub (the 2 +'s = 1 + inside...ect). this is a mono amp stable at 2 ohms so something else had to happen.
maybe you had it modded and you had it at 1 or below and were standing on it for a while (or low volts) or you had the compression (protect) circuit off (little tiny white button on the left) and the above happened
i think you nailed it jco
I've seen somebody do this once, similar results
idk much about the button either. i just know its there. thats why we have mtx website archives
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
811
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
shimmyz
shimmyz
PA
Crownvicon28s
    May 24, 2024
