Sure, Give me a couple minutes to take a couple. I already have the top offcan you get a pic of the board? to see whats wrong with it?
I hooked it up and the light came on. So I was happy about that. I didn't have a manual at the time and I'm not familiar with how these amps work. I hooked it up 2ohm on 1 channel. The volume was kinda low(not much bass). I knew It was 2ohm stable. So I bridged it at 2ohms. I now know its only stable at 4ohm bridged and 2 ohm stereo or whatever you want to call it (these MTX speaker connections are not what I'm used to). It worked for about 20 minutes at medium volume. It just stopped working and a little bit of smoke.that should be a fairly cheap fix. the caps aren't swollen so thats good.
how did you kill it?
thats dead wrong bro. no offense.I hooked it up and the light came on. So I was happy about that. I didn't have a manual at the time and I'm not familiar with how these amps work. I hooked it up 2ohm on 1 channel. The volume was kinda low(not much bass). I knew It was 2ohm stable. So I bridged it at 2ohms. I now know its only stable at 4ohm bridged and 2 ohm stereo or whatever you want to call it (these MTX speaker connections are not what I'm used to). It worked for about 20 minutes at medium volume. It just stopped working and a little bit of smoke.
The amp still powers up just no sound.
i think you nailed it jcomaybe you had it modded and you had it at 1 or below and were standing on it for a while (or low volts) or you had the compression (protect) circuit off (little tiny white button on the left) and the above happened
