MTX Thunder 81000D is Blown.. Sell it? Fix it? or Trade to MTX for TA7801?
thats dead wrong bro. no offense.
this is a mono amp (1 channel). what you see as 2 ch is just the ease of hooking up more than one sub (the 2 +'s = 1 + inside...ect). this is a mono amp stable at 2 ohms so something else had to happen.
I know its not a 2 channel amp. I used the term stereo and mono to simplify what I was trying to say. The Online manual states it the same way "Thunder amplifiers are not recommended for loads below 2 ohms stereo or 4 ohms bridged".
I am currently running an old Earthquake Magma 12 I've had for years. It is dual 3.3 ohm VC. It is wired parallel inside the box. I have 2 wires coming out of the box. The 2 wires carry a 1.65 ohm load.
The amp has 2 sets of speaker terminals. I will call them term 1 and term 2. I first wired my speaker wires(+ and-) to term 1. This didn't have any power at all. It sounded like 20 watts maybe.
Not knowing anything about this amp (as stated before). I then "bridged" the amp. (+ speaker wire to + of term 1) and (- speaker wire to - of term 2) . The power was much better it sounded close to my Soundstream Reference 700.
My car was running (well over 14 volts), low gain setting, half volume if that on the head unit.
I was in the car for about 20 minutes at low volume just getting a feel for the amp and pooof it was gone.
I'm sure my wiring had most to do with it. But why didn't the amp have any balls when I had it hooked to term 1?
That compression button looks to be strictly for protection of your speaker. Either way I was not pushing the amp anywhere close to clipping. So I doubt that had anything to do with it.
jco1385, I appreiciate your help. I'm not trying to sound like a smartass toward you. But some of these people acting like I'm an idiot isn't cool. I was very knowledgeable with car stereos at one time, but that was over 10 years ago. Ive never worked with an amp configured like this before.
Like how? using 1 terminal or bridged across both?
Im kinda hoping it was damaged when I got it. I was excited to hear 1000 watts at 12.5 volts. Instead It sounded like **** compared to my Soundstream that is rated at 700 @12 volts
Maybe I will get it fixed to see what it really does before I trade it off. The newer MTX amp has my eye though. But I'm an old school guy. I'm not sure I would feel right with a nice shiny amp in my ride.
either way is the same. you see "2 channels" but they're connected inside the amp. you can use either side or "bridge" it. it's all the same. it's all gonna be 2 ohm stable.
you put a 1.65 load on it it's not gonna burn up. it'll either go into protect (i doubt it) or push it.
Ok, I get what your saying. The manual make it alot harder than what it needs to be.
My light was and still is red. Does it change from green to red? Or is it always red?
Try hooking up the speakers at 2ohm or higher. the amp wont run below 2ohm without being modded.
the red light is the power light, when i first got my 1501d i also though that it was protect when it wasn't the case.
notice pics of burnt fets on 1st page....
edit: 2nd page
didnt see that, just read the last couple responses.
thats odd, these amps are built like tanks and are ran below 2ohm all the time, hell i run mine at 1 ohm daily.
maybe it was f'd up before you got it, and you blew another fet?
i know some amps work even with blown fets, my shitty lanzar does lol
If I do get this amp fixed I will either get 2 more magmas(if I can find nice ones). This will get me a 2ohm load. Or just Go with something new school. I just got back into car audio and I'm having trouble coping with what happened to this industry since the late 90s. New stuff kinda scares me (Quality wise)
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
4
714
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
5
shimmyz
shimmyz
PA
Crownvicon28s
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
