bro, that's cast aluminum. you might as well trash it unless you got mad welding skills like me. even then it's not worth it.beginning pics![]()
nice fuking avatar pimp! i like that.Shit didnt look that bad in the pics. Anyway to put some jbweld on the inside of the spoke for more support?
dont get mad buddy. just trying to help. word to your mother.i know what it is, and wouldnt waste my time welding it,
its 5 bucks if it dont work whoopy i wasted 2 energy drinks... like i need them anyhow
Yeah I bet you are great at welding cast aluminum.bro, that's cast aluminum. you might as well trash it unless you got mad welding skills like me. even then it's not worth it.
thanks, i'm actually a bad *** welder. mig, tig, arc, and torch. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gifYeah I bet you are great at welding cast aluminum.
So explain the process you would use to weld it. Just tig it? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifthanks, i'm actually a bad *** welder. mig, tig, arc, and torch. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
no not cast, too many impurities in cast so you'll pop holes in that sob. i'd either use aluminum spool from the mig with helium or alum. rod. then grind smooth. quit testing me.So explain the process you would use to weld it. Just tig it? //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
bullshit *******no not cast, too many impurities in cast so you'll pop holes in that sob. i'd either use aluminum spool from the mig with helium or alum. rod. then grind smooth. quit testing me.
