MTX 9500's vs. T3 Audio
bassin'96
Hi everyone. i was wondering this
to get some loud bass which is better for the prices:
mtx 9500 2 12's
or
t3 t.2000 2 12's
or
t3 t.s.n.s. 1 12
which would give me the most bass for my buck? i would be willing to build a custom enclosure and really DO NOT wanna do anything with the alternator or battery. just a capacitor and big three and possibly a bigger battery. i'm open to other options as well if you wish to recommend
there cheap *** spiders that rip, and saying subs play fine like that no need for a recone...
or maybe they go outta business once a year to Revamp there already revamped subs
T3 is known for shady business practices. The only thing they make that really stands out is the TSNS, but if you plan to run under 2KW it's a total waste. Ditto with the 9500 really, not a terribly efficient woofer, but nice sounding.
Get the T.S.N.S or the T-2000'S, great sounding subs, i have the T-1000'S 12's and have about 1500 wrms going to each of them. FYI i've seen only one instance where spiders were rip/small slits on T-3 subs, and that claim was made by the second owner of the subs, which where 4 10''s. I've had my subs since early march, and i must say , they sound bette and better each day. Also the T-1000,2000 and the T.S.N.S use the same surrounds, spider pack/material with the T.S.N.S having a couple more spiders.
Alright so what subs would you recommend?? the T3's will take too much too run. and the 9500's are overpriced
the battery is stock its just a stock good alternator that runs 220amps
Thanks buddy! Given me a lot to think about in terms of what to do; I've been watching YouTube videos on this stuff all day as well so I really...
756
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
In 1990: The MTX MTA 225 had a MSRP of 549.95 25x2 0.02% THD S/N 102 12x 8 1/2x 2 3/8 The MTX MTA 250 had a MSRP of 649.95 50x2 0.02% THD S/N...
bassin'96
bassin'96
Wisconsin
Bettr n' Revrse
    May 12, 2024
Brendon Jenness
    May 11, 2024
