mounting sub to box...
Originally posted by BigBoomer Dont you think you should mount the box to the sub? it sounds better that was(+10db's)
:p :p :p :p :p
each post you make, makes me hate you even more....i wont say the name because it is worse than most of the swears that get blocked out on here, but your reminding me of someone with the initials TT.....//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
Originally posted by Tungsten Ooo... paintball gun fed with about 150psi and some marbles instead of gell caps. //content.invisioncic.com/y282845/emoticons/satan.gif.9c6a335ed7aeeed3ee273e573f1fcaac.gif
lol 150psi is not enuf...my gun is low pressure and it runs on very low pressure (highly-modded gun...)
most stock mainstream paintball guns run anywhere from 600-800 psi.
trust me, i used to be hooked to paintball forums and i still own a nice gun... //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Originally posted by evo2k3 each post you make, makes me hate you even more....i wont say the name because it is worse than most of the swears that get blocked out on here, but your reminding me of someone with the initials TT.....//content.invisioncic.com/y282845/emoticons/nono.gif.eca61d170185779e0921b0faa9704973.gif
Thundertunes!!!!!!!!!
Originally posted by Tungsten The box itself will be a complete ***** to remove from the trunk so this will at least make a thief put some effort into his attempt while I'm getting out of bed, loading the Glock and pulling my shorts on. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
American History X?
I would put two Eyelets on front and back close to the bottom of the enclosure with Toggles, rubber washers, and metal washer to seal the...
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
323
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
BigRedMonkey
BigRedMonkey
Dallas, Tx
paikiah
audiobaun
    May 19, 2024
    May 19, 2024
