mounting amp onto sub box
There are several threads about this topic already. With various points from both sides of the fence.
Me personally, if the enclosure is build strong enough there is typically no issues from it. There are some amplifiers that are more prone to those kinds of damage, but they will likely fail just the same if you build something rather large with a good amount of output. The largest issue I have seen over the years are one of two things.
1. Enclosure flexes to much causing damage to the board of the amplifier by typically do to the "twisting" action that could happen.
2. Poor solder points and/or glue points on the amplifier simply break off. This was some what common of cheaper amps for several years. However, from what I have seen with the most basic Korean amplifier(what most run) that has been resolved.
If you can keep from mounting the amp on the enclosure then I would do so...however, if you have no other area to place it..then you really have no choice. Just take all precautions you can and go from there.
5/8 thick aluminum plate won't flex. Get a piece cut to the size of the top of your box. Also helps keel the amp.
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
Actually the pods do not impact the sound of tweeters at all, it's all about location, reflections and pods while great in some locations, can be...
523
Holefully he doesn’t hook batteries in series thinking it halves the voltage…..
29
It is a wives tale if the only evidence could be coincidental. I agree that vibration is bad for everything except women, but that doesn't mean...
32
6K
Beatin'
Beatin'
MI
™Caveman
    May 31, 2024
    May 24, 2024
