MLV Alternative Build
bradl79
I am doing an MLV build in my Doors and flooring, i only got my doors done so far so where is what it is so far
Products used
Acoustic Foam - Got it from Lowes, i forgot what its called and i can't find a link, but it is foam with some foil on it. - 44.99
dB-3 4 ft. x 8 ft. Acoustical Barrier (MLV) - 29.99
Gorilla Tape - Walmart (used to seal and tape down the mlv to door panels - Couple Bucks
Loctite High Performance 200 Middleweight Spray Adhesive, 13.5 oz (to adhear the MLV to the Acoustic Barrier) - 6.97 (at local walmart)
Cut out the acoustic foam to match my door panel and applied the spray to the back side, foil out
https://lh6.googleusercontent.com/-xYh_judMkMM/U1WkPsFG0NI/AAAAAAAAH-8/j2lvL_GW7ns/w1141-h642-no/20140421_172639.jpg
Layed out the MLV and applied spray adhesive to the MLV
layed the Acoustic foam on the MLV
back of the MLV
Acoustic foam applied to the MLV
fitting the MLV/AF to the door panels
Using Gorilla tape to seal to the door panel
Applied some deadener on the doors, i did do much on the panel b/c it was plastic for some reason and did not stick well, but i did install alot on the inside of the doors
blurry pic sorry lol
the thickness of the AF/MLV
More pics to come, once i can get to the flooring, then trunk and the rear doors.
i will need to get more of the MLV, i think 2 should be good enough.
It seems pretty heavy, my door panels had some weight to them.
So far with just the front doors done, i can tell a difference, i can barely hear cars passing me going around 30 to 40 mph and it was raining out, so i think once i get done it would be great and quiet.
That looks great. But may you can clairify one thing.
It does not look like you are using anything for dissociation between the Door and the MLV? Normally folks use a closed cell foam between the two.
thanks caleb, finally got all 4 doors done (no pics, just looks the same as the front doors), i need to get more to do that floors and trunk.
yeah about 32.00 if u just do the MLV,i really don't think u will need the acoustic barrier, i just used it b/c i had extra, one roll may be able to complete all doors, its gives u 32ft^3. i thought u had done ur doors caleb?
nice. the products are certainly affordable and not an "mlv alternative" because you are using MLV. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
just a version of MLV that is cheaper because it's used for homes and not cars and you get free shipping.
Haven't used mlv on doors //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Only on floor
bradl79
bradl79
NLR
bradl79
