The passive crossovers that come with the Germaniums do two things
(a) They high pass the tweeters (@ 2.2 or 2.6khz)
(b) They low pass the woofers. (@ 2.2 or 2.6khz)
What they do not do is high pass the woofers. While you can run the germaniums full range without any high pass crossover, i would not push the volume too extremely with that setting...a 6.5 inch driver simply gets jacked when you start trying to tell it to play 20hz to 2500hz. 63hz/18db is probably fine, and i ran mine @ 80hz/12db high pass. I eq'd up slightly on my (ghetto *** un-deadened and no baffle) install at 120hz and 200hz. I don't think the highpass x-over @ 60hz is the problem. Midbass is at least 80hz+...all the way up to ~200-250hz. Unless your high pass crossover is something extremely shallow like 6db, it should simply be doing what you want - cutting out bass so your sub can play that while your 6.5's play midbass and midrange. I've played my set without any subwoofer for a while and they produce a surprising amount of volume @ 60-100hz considering their size... they merge very well with my 12w6 (poor 12w6.)
