MB Quart DSC4125 review
fuse rating on most new amps is irrelevant anymore. you cant base an amplifiers potental using a fuse rating, thats all old school AB stuff that means nothing now.
I beg to differ. Unless an amplifier manufacturer found a way to violate Ohm's Law, the fuse rating is usually a dead giveaway.
Volts x Amps = Watts
Watts x Efficiency = your real world power output, no matter what the topology of the amplifier is!
Yeah the fuse rating is by no means 100% accurate, but it is good for a ballpark estimate.
Of course i have seen it go the other way where some manufacturers would recommend a fuse rating higher than their product can handle. That is almost as bad as a certain Brazilian manufacturer who claimed 2,400 watts RMS on 120 amps of fusing.
Cause I'm a nerd, and believe in Ohm's Law, you'd need 28V alternator for that kind of sheeze.
That aside, the new Maxxsonics stuff is showing alot of potential, and the 4125 is a darn good value.
I like the fact that the 2000.1 has anodized blue heat sinks on the FETS... if that doesn't give ya a boner, I don't know what will. //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
note: there are 14VDC components in there, so I wouldn't plan to **** this amp with voltage.
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
05fronty
