Maybe doing a change?
PapaGeno21
Captain Questions
Ok so I just installed a new system into my car. I really like it so far.
The front doors take 6.5 components and the rear doors take 6.5 coaxials. ONly problem is they need to be shallow. I think the max is goign to be just udner 3" if I use a spacer.
Just put Kicker DS65.2's into the front doors (these are just under 2" and did not need a spacer). I know they are the cheapest line but I am not amping the door speakers. I just don't listen to music that loud. However I left the rear doors stock. I am I would say 80% happy with these Kickers. I am thinking about putting these into the rear doors (I can mount the tweeters on the panel) and then getting the RE Audio 6.5C's for the front doors.
Do you think this would be a good plan?
Its an 05 outback wagon. Pioneer AVH-P1400DVD Headunit, Big three done with 0 gauge, Kicker ZX1000.1 Amp in back with 4 gauge running to that, (2) RE Audio SE-X 12's in a sealed box.
Highly suggest running an amp to get the most out of any comps. It makes a big difference. You don't have to listen to it loud, but an amp will add authority and details in your music compared to most HU's.
120 and under. Not looking to break the bank as they just gotta be a bit better than these kickers and I will be happy. Like I said I'm 80% happy with these kickers so yeah.
id eq at the db you listen to the most often. our ears dont hear things the same, at different volumes. why tune at 60 dbs, when you listen to 90
10
778
Yeah... check this link out. It shows the power handling of that tweeter. I'd just match the power no matter if you use the crossovers or not...
939
Upgraded speakers in my 2023 EX X-line with the 4 speaker stereo, but it definitely needs an amp. The volume of this system is terribly low. My...
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
PapaGeno21
Captain Questions
PapaGeno21
Rhode Island
PapaGeno21
maylar
    Jun 2, 2024
    Jun 1, 2024
