IDSkoT 5,000+ posts
Resonating Reticular
x2honestly nothing is theft proof because if they want it they will do what it takes to get it. I did an install in an explorer and I use torx screws on everything because it what we use at work. well when his car was broken into they couldnt unscrew the subs so they took a sledge to the box and busted it apart till they could get the subs out....
But that's smart on the thief's part.
However, he's completely right.
I've seen some cases where since the guys couldn't get the subs out, they just took their screw driver and rammed it into the cone. Recone cost less than a driver, but still. Just get a bunch of Piezos in your cab. (hooked up to your alarm, of course)
2-3 Piezos mounted on the outside of my friend's car, I couldn't stand within 10 feet of it with out cupping my ears or writhing with pain.
2-3, even upward to 5 in a CAB? You won't be able to stay in there. Literally you won't. You won't be able to concentrate hard enough to even unscrew a sub.
It's also important to note, thieves don't want boxes. They want subs.
So, making sure your sub is theft proof is much more important than making sure your box isn't theft proof.
Depending on your box, it could weigh between 50-100 or more pounds... that plus the 20+ pound driver(s) adds up. You need 2 people to steal a box, at least.
You only need one to take 2 drivers. Use safety screws... that's the only thing you can really do. Unless you use a chain connected to your subs which is locked to your chassis. //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
