Major voltage drop
rada194
Okay so when I'm driving my car my voltage will go from 14.6 down to about 13 volts when I'm really pounding it. When I pull up to a stoplight my voltage will stay at 13.6 and drop very badly. So I've come to the conclusion I need another battery. We'll here's the thing. I have an advanced auto autocraft gold battery rated at 800 cca. Would that work and if so is it ok because I believe that battery would give off some kind of gas in the sealed environment in my trunk. Also how do I run that battery do I have to make a second 0 guage run or what?
And just incase my system is 2 12 inch pioneer subs. Pushing 500 RMS. In a custom ported box that I made.
What amp are you running?
---------- Post added at 06:21 PM ---------- Previous post was at 06:21 PM ----------
And what's factory alt?
---------- Post added at 06:22 PM ---------- Previous post was at 06:21 PM ----------
What amp and what's the factory alt?
Okay don't laugh. But it's a lanzar htg 257. It's a 2000 watt but doesn't put out anywhere near that which I know. I bought it because my subs run 400 rms each and this lanzar is capable of putting out about 950 watts rms bridged.
The alternator is the factory one it's a 94 grand marquis so it should be putting out like what 135 amps or something.
Okay don't laugh. But it's a lanzar htg 257. It's a 2000 watt but doesn't put out anywhere near that which I know. I bought it because my subs run 400 rms each and this lanzar is capable of putting out about 950 watts rms bridged. The alternator is the factory one it's a 94 grand marquis so it should be putting out like what 135 amps or something.
There you go....Cheap amp an i bet you have no big 3 upgrade rite. I had a Boss "3k" amp that would pull on my elec system the same way. Believe it or not my much more powerful zxs1500.1 made my lights dim a lil less even thought it is 5x the amp. Just better quality i guess. So yea get an AGM an Big 3 then a real amp. Especially if u made a box. All 3 upgrades will run u $5-600 but if ur a BassHead its well worth it
Big 3 is done already and so your saying the autocraft battery won't work in the trunk as a second battery.
No its not a sealed battery, hella danger zone....thers ways around it, but that requires vents an all. Just invest in AGM batts
Alright lmao that's what I thought. Ok so I'm gonna look into getting a sealed battery and a new amp. Thanks a lot man!
I thought it say'd AutoZone....but that AutoCraft it an AGM is it not? If so it'l work in back....Tons if Tutorials on Youtube on how to hook up a 2nd batt
No it's definately not a sealed agm battery. It has the little caps you pour acid into.
Well yea....deff look in to an AGM i jus made a couple threads about High an Low end AGMs. I just got a DieHard for my Camry $175 w 3yr warranty
rada194
rada194
Miami, Florida
MakkMar10
NorthFramingham
    Jun 30, 2026
