got 2 12 type rs and made a 5.50 cube at 34 hz and installed it today and it is just distorting bad at low volumes just getting worse if i turn it up a little. even at low volumes i can hear the distortion. whats the problem wired up at 2 ohms correctly to a 2400 orion. i thought a ported box would hit hard and clean. it sucks bad, help......also the box plan only has 1 portwall going from th efront to the back but nothing coming across the rear of the subs. is this causing the subs to unload.? but since i made it to spec i thought it would sound good
