main power wires to disto block or rear batt.
  • 2
108
sc
I ran my 4/0 welding cable power and ground from the front batt to the cargo in my explorer today. Question is should I put them on my rear batt then to my distro or can I put them straight to my distro blocks then just wire of the block to my rear batt, amps, etc. I made some beefy blocks out of aluminum 9.25×2x1.25.
Haven't put the rest of the holes in because I'm not to sure the best way to run it
Sent from my LG-D850 using Tapatalk
are you able to put the blocks directly onto your battery posts? i dont really think its going to make a big difference either way in this situation, although id probably run it to batt then distro if you think of how the current is going to flow
I can drill and mount straight to rear batt but might look a little fugly cause of how big they are(might have made the a little to beefy). I believe I'm go in to mount them on a piece lexan or mount to the side of the box running mains to rear batt then distro blocks to keep the flow right like you said.
What equipment are you using? It can be done physically (placement of sub), electrically (reversing wiring), electronically (DSP). If your amp has...
826
Thank you to everyone who has given me advice so far. I have not had the chance to make any changes yet (truck driver). I don’t get much down...
Who had that Badazzed Astro Van?? I remember going to Austin seeing that ride. That thing made Earth pavement move about 50 ft before I got close...
477
awholelotofnutz
sc
awholelotofnutz
    Jun 1, 2024
    May 31, 2024
