Jandry
A long time ago I posted a thread here trying to get suggestions on speakers and to get a critique on the rest of my system. That thread is here: http://www.caraudio.com/forums/general-discussion/612612-critique-my-system-suggest-some-speakers.html
I ended up with the following installed in my truck:
Pioneer DEH-80PRS
Polk Audio PA-D4000.4 Amp
Pioneer TS-D 1602R 6.5" Coaxials
Pioneer TSSWX2502 10" Compact downfiring sub
(Amp channels 1 and 2 driving each speaker; channels 3 and 4 bridged for sub)
Truck: 2002 Ford Ranger XLT Supercab (sub downfiring behind drivers seat)
Music Prefs: EDM (Trance, House, Dubstep, some Trap), Metal/Rock/Alternative, Classic Rock, some country, some rap, and a lot of various pop stuff.
The speakers and sub were/was basically temporary as Id planned to go with better eventually. Recently, I replaced the TS-D coaxials with JBL P660C components (tweeters on doors off axis, -6db passive crossover cut), and have the money to do the sub now. I plan on going with a 10" or 12" sub. I have to do the sub because the JBLs are so awesome Id have to level match them into oblivion not to drown out the sub. As it is now the front stage is awesome and the sub is adequate, and Ive only got 75wrms at the P660Cs...
I have 400wrms to drive the sub, and it must be a 4 ohm setup (amp is only 4 ohm stable when bridged). Based on what ive learned, to get the loudest clean bass I need a sub thats 4 ohm single voice coil rated for 3-500wmrs and with high sensitivity (90db+ @ 1 watt). I know if I push close to the 400wrms ceiling of the amp, I need to oscope it for clipping and I will. I came up with the following:
Polk Audio MM1040 10"- 350wrms, 91db @ 1 watt, 4ohm SVC, .66 cuft sealed box
Polk Audio MM1240 12"- 425wrms, 92db @ 1 watt, 4ohm SVC, .88 cuft sealed box
Since I can fit both, im leaning towards the 12 as its more sensitive, rated for more power, and has more cone area. However, I do need it to be capable of tight bass (like double kick bass in metal), and ive read alot of opinions saying 10s are tighter. Id like to stay sealed. Can any of you give me advice on what would give me the best clean bass? Are these subs good? Is there some other high sensitivity sub thats better?
Pioneer DEH-80PRS
