hatedonmostly
throwin' hunnits, hunnits
Did a 143 on a 2200D iirc, sealed on the dash; 147 outlawDid you guys meter it by any chance? I believe I did that box for him.
Do you remember what frequency? I tuned that thing pretty low, like 31hz...those hatches really shine when metering outlaw too.Did a 143 on a 2200D iirc, sealed on the dash; 147 outlaw
It was pretty low like below 40 for sure.Do you remember what frequency? I tuned that thing pretty low, like 31hz...those hatches really shine when metering outlaw too.
Actually my point is that more power is rarely the correct or smart answer. Sending more power is playing a game of diminishing returns, rapidly diminishing.failure to provide enough power in order to get the results that you desire(assuming said sub can handle the power needed) is "underpowering," plain and simple.
But again, if said sub can handle the power(both thermally and mechanically), and the added power gets them more output(which they want), then why not? Altering the box to be more efficient has it's downfalls too, and will most likely not give you the same response curve without lowering the tune(assuming you're going with a larger box to be more efficient, and are currently happy with your response curve). Then you have to deal with sloppier transient response and higher group delay with the larger box in exchange for a little more efficient box.Actually my point is that more power is rarely the correct or smart answer. Sending more power is playing a game of diminishing returns, rapidly diminishing.
A buddy of mine is running a sub that handles 3k and is only feeding it about 700 watts and the thing is absolutely slamming. Sub is barely moving (very little excursion) yet putting up crazy numbers on the term lab. A buddy of mine who owns a fully loaded BTL 15 was completely shocked on how loud and clean it sounded.More power doesn't always make it perceptibly louder is the point that you guys seem to be missing. Depending on the specific sub and enclosure it is possible that you can double power without getting a dB increase in output. The closer you get to the power limit of a sub the less increase in output you're going to see by adding more power. If you've hit the point of diminishing returns and it still isn't loud enough, more power isn't the solution. More/different subs and/or a different box is.
The real problem is unrealistic expectations or expectations that do not align with the equipment in use; not running less than rated power to a sub. I see way to many guys that post about being unhappy with the output of their system and when they state that they are running 1kW to a sub or subs that can handle 1.5kW the answer that they always get it "you're underpowering those subs." The reality is that the increase from 1 to 1.5 kW will rarely give them an extra dB, thanks to power compression, and certainly won't cure their woes.
I was waiting to see that.The sensitivity spec is worthless on a sub since it is derived at 1kHz.
I agree with this, but I never once stated in my examples that I was reaching the point of diminishing returns. With my current setup, I can move my sub maybe 1" p2p with clean power from my amp...I've personally seen it move 2.5" p2p with more power, and I can guarantee you that it was quite a noticeable difference in output. That's more like a situation that I was trying to describe, where you have not even come close to mechanically maxing out the woofer and putting more power to it will increase driver displacement two-fold.If you've hit the point of diminishing returns and it still isn't loud enough, more power isn't the solution. More/different subs and/or a different box is.
I agree.The real problem is unrealistic expectations or expectations that do not align with the equipment in use; not running less than rated power to a sub. I see way to many guys that post about being unhappy with the output of their system and when they state that they are running 1kW to a sub or subs that can handle 1.5kW the answer that they always get it "you're underpowering those subs." The reality is that the increase from 1 to 1.5 kW will rarely give them an extra dB, thanks to power compression, and certainly won't cure their woes.
